Ebay Knock off Klann Compressor? opinions please?
Above is a link to a compressor Kit. I know it is a knock off. Has anyone ever used one and will it safely work. Is there a better alternative?
Gary
This would be such a situation... However, I really would like the ability to try out the H&R Sports on my car without an install fee
be very well made, sturdy, and shows no signs of fatigue....this coming from someone who
is just a weekend mechanic, ie anecdotally. i always try to minimize handling of the spring
in compressed mode, and as soon as I have it in hand, i place it on the ground with the
ends pointed in 9 and 3 o'clock orientation. i release the spring tension as quickly as
possible and the springs never stay compressed more than 5 mins when they are off the
vehicle.
i opted to purchase as I knew going into my project that I would be pickey with the tire/
fender gap, and that it would be a trial/error project spanning months. in the end, i was
satisfied with the purchase of the clone spring compressor.
oh, btw, i recognize the seller of the spring compressor posted by the OP. I live nearby
and have purchased MB and non MB tools from him in the past. he works for MB. good
guy.
Thanks a bunch for all the input. I am putting in the order today.
vehicle.
guy.
If anything, doing the process yourself should feel more comforting...who knows the guy at the shop was having a bad day and decided he didn't want to go find the torque setting for your caliper mounting bolts
I'm sure this happens a lot more than you'd like to know...
i used the klann clone, i wore large face shield (woodworking design),
mechanics gloves, and once the compressed spring was on the ground, I
place a large sheet of backpacker's foam over it to help (somewhat) control
flying metal bits should it explode.
by the time I got to spring compression #5 or 6, i was more skilled, and
especially, in working swiftly and smoothly to where I didn't use the foam.
but I continued to wear eye and gloves.
2. wear gloves
3. take your time
4. you're not going to die
5. watch for the placement of the plates when installing the new springs.
6. keep things clean and organized.
* I always use jack stands when working on my car and a tire under the car . I was working on a mustang and the jack failed and the car almost fell on me.
I've rented and used this same compressor about 5 times. Last time it took me 15 min to remove the springs on each side and 15 min to put them back on. You'll spend most of the time trying to remove the spring pads. Wear gloves anytime you mess around with the suspension because you don't want bloody knuckles or fingers.
When removing the springs put the plates close to the top and bottom and put a little bit of tension on the compressor and readjust the plates. Put a jack under the LCA and lift it to compress the spring. Finish compressing the spring and remove the jack. This way you don't have to do a lot of wrenching.
When you put the new spring watch for the top plate. You don't want to put it too far towards the top because when you install it and uncompress the spring it's going to get stuck on top. Install the new springs with the spring pad on it. It's going to be harder if the pad is on the perch. Have someone push down on the brake caliper so you can have more clearance to install the spring.
That's about it. You should be able to figure out anything i left out.
2. wear gloves
3. take your time
Any ideas what I am doing wrong here because I read you do not need to?
Bowl approaching, i was getting frantic...and annoyed. I encountered
similar, ie I couldn't compress the spring enough to remove.
note the pic, about halfway down, in which I was able to get a bit more
clearance by removing the lower link in the sway bar, and putting a little
downward pressure....while tipping and removing the spring. can this
technique be applied to your situation?
yes, i did remove the nut off the top of the shock as well
