Skip in a 1995 E320 heartbeat
Old Jul 5, 2010 | 02:01 PM
sasjzl's Avatar
1995 e320 Wagon
My 1995 E320 is skipping a beat, has a very slight misfire that does not seem to affect its performance but is really irritating me and making me worry about it worsening. I have already replaced the plugs with the specific Bosch plugs that are required and the coils and plug wires were replaced not very long ago. Maybe 10k miles. It has 214k miles on it. The idle still appears solid but if you put your hand on the top of an open door you will see the misfire in your hand.
I am just wondering what I could look at after the plugs and the coils and wires? Is there a code I might be able to pick up? The check engine light is on already because of an EGR problem that I cannot get right after cleaning out the tiny pipe that goes into the manifold during a head removal job and replacing the egr valve.
Thanks very much,
Jim Lee
Old Jul 15, 2010 | 12:52 PM
Qbsbear's Avatar
1995 E200 W124
Best advice i can give is to replace egr valve and then have the codes read to see what it might be causing although i think the egr valve might be the cause of your problems
Last edited by Qbsbear; Jul 15, 2010 at 12:53 PM. Reason: Duh Brain refuses to work
