Door lock problem?
Old Jul 30, 2010 | 02:34 AM
funkgab's Avatar
1987 300E, 1995 C280
Door lock problem?
so power locks work, vacuum has no pressure problems.. but the drivers side just won't activate the vacuum? passenger side works fine..Is it an actualator?
Old Jul 30, 2010 | 02:37 AM
Sathinas's Avatar
S65
Actualator? Vacuum by definition will never have pressure.
Chances are there's a leak in the door lock bladder.
Old Jul 30, 2010 | 11:46 AM
funkgab's Avatar
oh w124s don't use actualators?
so i should take apart the interior panel and check for a leak?
Old Jul 30, 2010 | 10:48 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
I'm not sure I understand your post clearly, but if the vacuum pump runs when you turn the key but the door does not lock/unlock, you need to look for vacuum leaks in the lines from the pump to the doors or look for a bad diaphragm in the lock actuator itself. If the pump does not run when you turn the door key, the actuator switch or the wiring from the door to the vacuum module is bad.
-FD
