1995 e320 - intermittent engine clicking
Old Sep 6, 2010 | 09:19 PM
HVF's Avatar
HVF
95 e320 Wagon, 98 s320 LWB
Any thoughts on intermittent engine clicking on a 1995 e320 (M104 engine). Seems to be coming from rear part of engine, sounds like a tappet, but comes and goes. Used a mechanics stethoscope to try and isolate it but only can tell it is from upper rear area. Sometimes happens when idling, seems to go away at higher RPMs. I have been using Castrol 20W50 oil for some time in all my previous Mercedes.
What sound does a noisy fuel injector make?
Thanks for your thoughts.
Old Sep 16, 2010 | 03:38 PM
Frank Nitty's Avatar
1987 260E, 2008 GL 450,1980 240D 2002 Chevy Tahoe LT
Are you sure its not an exhaust leak from the manifold gasket?
Old Sep 16, 2010 | 07:48 PM
WDB124066's Avatar
1996 E320 Sportline Cabriolet x 2
May be it is one or two of your hydraulic lifters are a bit weak. Sometimes they get a little gunk in there. Mitsubishi have an oil treatment specially for their engines that is said by MB mechanics here in NZL to help clean out and minimise the clicking noise. When you do an oil change use an engine oil flush too. This will help clean out any deposits you might have that they say tend to contribute to the problem.
Old Sep 17, 2010 | 07:15 PM
HVF's Avatar
HVF
I wondered about both an exhaust leak and a lifter. Seems to be intermittent and mostly at low RPM's. I normally use Castrol 20W50 oil (habit from Mercedes diesel cars). Maybe the 104 engine doesn't like the heavy oil.
