staggered wheels
Has no beneficial effect..
Regardless of rim diameter you still need to maintain about a 25" overall tire diameter to keep everything to spec.
Larger the rim, the less aspect ratio you'll require in the tire.
No standard 124 ever was delivered with a staggered, be it width or diameter rim setup...
Conversely, a tire with a larger sidewall (to a point) will provide better turn-in grip in front, because it will stretch to a small amount, while holding the road. Drifters will run this setup to more easily break the rear tires loose, and still have adequate grip up front to keep the car pointed in the right direction.
Plus, it does look cool on some cars. Not sure how it would look on a w124, but hey, try it man! Make sure and throw up some pics.
Don't act like you don't appreciate the grace and skill Mark!
Basically, I wouldn't trivialize drift as a form of driving/racing. It is legitimate IMO, just different. That being said, the w124 makes a amazing drift candidate. If you checked my latest SCCA runs the car was pretty much in full drift the entire lap. Had I some more power and more appropriate setup, I would have had some insane drifts going on. As it was, I had the announcers up in arms about how "I had no idea this was a drift event. And our drift car is a Mercedes... with a vortex generator?"
http://www.youtube.com/watch?v=sBtU4jxpPxo
