help needed on 1993 300CE.cab
300CE 1993 cab
I have several issues to work through
a power to pass window motor all the time ignition is on.. bad relay? where is that relay.
b headrest in up position, I can not get the drive motor to engage to retract them.. help please....
c. need to rewire throttle body
any input would help greatly!!
300TE / 300E / 300CE
b) front or rear? Check the fuse and relay. If front, try to push it down while holding the headrest button down. worse case, remove the rear seat panel and inspect the motor.
c) what symptoms? insulation flaking? inoperable? There is at least one thread you should be able to search "ATA"
95 E320 Cabriolet, 108K
a) control unit is under rear seat, passenger side, PN 124 820 48 26. Probably a stuck relay. There are eight in the unit. Clean them all.
b) do you hear any noise while trying to operate the headrest?
c) Search "ETA", not "ATA"
