A/C fan not turning on....
Is there a switch i can check or is this something more complicated...The clutch does turn on as a little fyi, and at night my a/c blows cold and does auto control when it reaches the appropriate temp. Any advise?
You may have a problem with with the fans themselves. This is an easy test. With the car off, spin one of the fans as fast as you can by hand. The other fan should also spin, but slower (the first is acting as a generator thus turning the second one). Do the same to the other fan an look for the same. If they both behave, the fans are good.
You may also have a problem with the high pressure "super heat" switch. This is located on the receiver-drier on the front left side of the engine compartment. There are two pressure switches located there (the other is the low pressure switch that protects the system from refrigerant loss). With the A/C on, jumper each one, one at a time. One should turn on the A/C fans, full speed (assuming the fuses are good). If yes but the fans still don't come on when the A/C is running, it must be replaced.
Hope this helps,
- FD
Last edited by Floobydust; Oct 17, 2010 at 10:25 AM. Reason: corrected error in statement (don't post late at night!)
