New member with a question...
Old Nov 29, 2010 | 12:37 PM
Barry Miller's Avatar
2003 E-500 & 1994 E420
I am new to the forum and also new to MB ownership (but now I have 2, I was so impressed with the first I went and bought another); question is, where is the connector for the CD player on a '94 E420 Sedan and what model CD unit does it require for that year model? I have seen several for sale on ebay but don't know which model fits my 420. Thanks,
bm
Old Nov 29, 2010 | 01:14 PM
Saijin_Naib's Avatar
1990 300ce 24v I6
Do you have the stock Becker Tape-deck radio? Then you need a Becker Silverstone CD Changer. I think there are a few other models that will work, but that is "the" one to use.
As for the connector, I've not the foggiest. I'd check in the trunk area behind the molded carpet and maybe on the top of the trunk (the bare metal part)
Old Nov 29, 2010 | 02:33 PM
I do have the stock Becker radio. I haven't seen the model you mentioned listed, as such...they are always listed as "Model 3296 with the 10-pin connector..." "make sure yours is this type connector.." and so forth, in the ad; some have 9-pin connectors and plug in differently.
Old Nov 29, 2010 | 02:47 PM
1990 300ce 24v I6
Hm, I'm not sure then. I currently have the Becker CD 4602. It uses the ISO connectors and plugs directly into my 1990 300ce without issue. I don't have a CD changer because I hooked a 3.5mm AUX-Input cable up to it and play music from one of my many Mp3 players.
Old Nov 29, 2010 | 03:05 PM
ZedStyle's Avatar
Youngtimer
it should be on the right side wheel well, behind the carpeting...
Old Nov 29, 2010 | 03:47 PM
190E 16V's Avatar
1987 560SL
Go to this forum for exact info:
http://www.500espot.com/forums/searc...=active_topics
Old Nov 29, 2010 | 04:11 PM
yes, that's where it was. Thank you very much; I suppose this means I must need a model 3296 since that's the connector that model takes...plus it fits the model year also. I'll peruse that other website also and see if I can glean any other useful information from there. Thanks a lot guys!
bm
