Engine mount - Adjusting?
Old Dec 2, 2010 | 06:25 PM
spetz's Avatar
1994 E220 Coupe
Hi guys,
I've recently swapped the engine mounts.
I was wondering, do they just get tightened as they are one placed, or should the engine be rocked/turned on etc before tightening the bolts?
ie, so that the mounts "seat" properly?
Old Dec 2, 2010 | 09:18 PM
ESTJ's Avatar
2001 E55 AMG - 2001 E320 - 1990 300CE
Tightening Mounts
The process that I used successfully was to loosen the transmission mount first, then replace the engine mounts with slightly snug bolts, then give the engine a couple of good shakes from each side, then torque the engine mount bolts to spec and re-torque the transmission mount to spec.
Hope it works for you!
