Cold air intake
Old Jan 6, 2011 | 08:20 AM
spitfire980's Avatar
2007 Lexus GS300, 1992 SL300-24
Cold air intake
Hello
I would post this on the R129 forum but its mostly dominated by the V8's and you guys have more knowledge with the M104
I am currently awaiting the delivery of a BMC CDA airfilter and my question is,
is it viable to purchase another BMC CDA airfilter and run them on each side of the engine bay connected by a Y-pipe at the throttle body
Old Jan 6, 2011 | 03:12 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Originally Posted by spitfire980
Hello
Why?
Your stock air intake provides more then enough volume for an unmodified M104-24V.
Old Jan 6, 2011 | 04:59 PM
An eaton m62 supercharger is in the works but im currently working on the breathing and exiting with a decated quad tip brabus exhaust system
Old Jan 7, 2011 | 04:25 AM
sort of similar to this setup but with ceramic coated aluminum pipes with a Y-pipe at the throttle body
Attached Thumbnails Cold air intake-amg300te34b11.jpg   Cold air intake-124-engine-air-intake.jpg
Old Jan 7, 2011 | 08:21 AM
RBYCC's Avatar
Why not leave it alone until you install the supercharger?
The whole dynamic as far as AFR will drastically change after you boost the motor.
Old Jan 7, 2011 | 02:25 PM
the general consensus is that this setup will gain little to no extra power, most prob gona stick to one BMC CDA airfilter until the supercharger arrives
