How noisy is your engine?
Old Jan 16, 2011 | 08:10 AM
spetz's Avatar
1994 E220 Coupe
Just wondering how much noise from your engine is sent through to the cabin?
In my C124 (E220) the engine is quite noisy and generally is the noisiest thing. Even on the highway there is more engine noise than tire noise or wind noise.
Is this something that is only apparent in the 4 cylinder cars or even the 6 cylinder ones?
I would expect that with the double firewall design it would be pretty quiet.
Old Jan 16, 2011 | 02:48 PM
BlackStar Stig's Avatar
W124 230E 1990
In my 230 I only hear my engine if I give it some pedal, other than that the noisiest thing in my 124 is my wife..
Old Jan 16, 2011 | 06:20 PM
spetz's Avatar
1994 E220 Coupe
My 220 gets loud in the higher revrange (say 4500+)
I would expect the M102 to be much noisier than the M111. Maybe it's a matter of perception
Old Feb 1, 2011 | 04:06 AM
abosharu's Avatar
W124
Replay- How noisy is your engine?
Hi there.
Regarding you problem, I'm faces the same problem with my MB W124 E200 1995
what I do just to washing my inside engine :
by using (power oil 1 KG + 5 KG Kerosene) so the total is 6KG
like when you change your engine oil with filter it's the same capacity, later just turn on your engine for 5 min. and empty it again
to be assure your engine is clean
when you finish previews thing putt 1 KG engine oil and turn on for 1 min.
so far you’re ready to put your new oil filter & oil engine
