124 rear suspension upgrade
Is this an OEM upgrade from Benz?
I will check my control arms when I'm next under there. Thanks for the info pkmaven.
BTW I'm sure there are plenty of rubber bushes on an 87 car that could do with changing..sometimes it's best not to look
I read on one of the forums that the TE link would fit. In fact, I have read that most things fit all the W124s. There are some issues with the air suspension and maybe something with 4-matics. There are also some differences with 8 cylinder vs. 6 cylinder cars. For example the front swaybar from the 6 cylinder does not fit the 8 cylinder, but the 8 cylinder bar fits the 6 cylinder.
I am just going with what the guys on the forums suggest, but it is really great when you can get the same answer from a number of different posts. I especially like well documented installs with the pictures and part numbers. The details always give me a lot more confidence.
This is the link that is closest to the sway bar frame mount. On early 124's (86-89) they are almost *always* worn out, as show in the photo. The rubber is just disintegrated. They're about $30 each for the new part, you will need the new bolt kit AND the bolt sleeve as well (the bolt size is different). The dealer (or Rusty, 800-741-5252) will have the info you need. The strut was also reinforced greatly, as you can see. The other links have been strengthened as well (now all 210- part numbers, I think). However this torque arm is the one that usually is the worst (may be better on 1990-up cars). The other links are usually OK, but the lower spring link (the really big one on the bottom) can have the bushings wear out on BOTH ends (check inner AND outer).ksing, the sway bar end link is totally different. The part number for the metal link is on the infamous sway bar spreadsheet/PDF file (it's 124-320-04-89). Whoever said it's not sold anymore should be slapped upside the head. It's on the MB-USA price list for about $20. It may be special order from Germany, but even so, MB Europe shows it is available:
http://wwwsg.daimlerchrysler.com/Pro...y&etpl_lang=01
Good luck,
Aluminum torque arm looks pretty and is probably stronger. Plus it costs twice as much so your wallet will be lighter, making the car go even faster.
Does anyone have a link on how to install the #210-350-33-06?
I bought 2x Lemfoerder arms, and 2x mounting kits. I just need install instructions (and the size of the torx bit too please?)
Thanks!
