1988 300ce engine wont start help!
1988 300ce
engine start and instantly shut off even i rev it high it wont stay on no more than 2 seconds and when i looked to speedometer the RPM didnt move just stay on 0. got checked my mechanic yesterday he said fuel distributor, and after i told him the RPM didnt move he said 90% ignition control module is the problem. so my question is which one is most likely the problem? thanks for any advice
300 mercedes
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Start with the OVP which distributes the speed signal.
1988 300ce
ok, so the problem was the fuel pump fuse i think, the little box behind the battery that has 10amp fuse, the fuse was blown and now everything is working fine. Thank You for all the advices Thank You!!!!
