problem starting 230CE
Old Feb 22, 2011 | 08:34 PM
germanad's Avatar
W202
Hello people
I start it, leave it to warm and stop it
When I want to start it again it does not start, the engine turns as if he was not injecting
I leave her to cool and it starts in 1 second
This warm when, I extract a relay that is behind of the battery (they are two, but I extract of forward) and put another relay like that works well and the engine starts, but I stop it and then does not start, it is not a problem of this relay but it has to see something
Old Feb 24, 2011 | 11:08 AM
germanad's Avatar
W202
upppp
Old Feb 24, 2011 | 11:16 AM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
The two relays near the battery are the OVP and the FPR.
The OVP has a fuse on top.
The speed signal goes from the OVP to the FPR which keeps the fuel pumps running.
My guess is that one of the relays is being affected by heat.
If you pull the relays and shake them do you hear a rattle?
Both are inexpensive and if original or old should be replaced.
Old Feb 25, 2011 | 07:23 PM
germanad's Avatar
W202
the relays are OK because i tried with the another car relay.
one of this relays is the fuel pump relay
