Help w/500
Old Feb 27, 2011 | 10:13 PM
RPB's Avatar
RPB
Help w/500
My 500 recently has been idling a little rough at lights, occasional delay in throttle response, bad gas mileage, and odd exhaust smell. Very low mileage car and well maintained. No cel light. Could be bad O2 Sensor, but thought it would usually trigger a cel, so not too sure. Car seems to be running too rich. Any ideas? Thx!
Old Feb 28, 2011 | 02:05 AM
shenagles's Avatar
1990 300e24
maybe the cat?
Old Feb 28, 2011 | 09:38 AM
RPB's Avatar
RPB
Originally Posted by shenagles
maybe the cat?
Hope not, no issue w/acceleration and car recently had stringent emissions inspection done. I say bad gas mileage but I am getting about 15-17mgp, so I think avg for the 500. Never replaced MB cat before and own a few with high mileage, orig cats.
Old Feb 28, 2011 | 06:02 PM
AMG140.6's Avatar
Stg3 B5S4-C55 AMG
Sounds like you need a distributor cap and rotor kit, also might want to check the EZL unit.
If those 2 are ok, then have a look at the throttle body unit. They go bad, but can be rebuilt. Too expensive to buy a new OEM one.
Search the web for W124 500e throttle body rebuild and you'll get a link for the place that does them.
Exhaust smell might be from leaking VC gaskets ? 17mpg isn't great for the M119 motor but not that bad either....the norm is 18-20 mpg hwy.
HTH
Old Mar 1, 2011 | 12:34 PM
Jim's500E's Avatar
The odd smell of the exhaust would point to a bad/clogged cat in my mind...what sort of mileage is on your car? They have and do go bad. Crawl under there and wack it with a rubber mallet and listen to see if there are pieces loose.
I happen to have a good used M119 TA for sale btw if it is that, but I doubt it is.
Old Mar 13, 2011 | 02:37 PM
larryj's Avatar
2004 SLK 230, 1992 300E & 400E
To determine if it IS the converters, and if you have an O2 Sensor between the cats and the engine, just remove the O2 sensor and see if that helps your situation. If so, it's the cats.
Old Mar 14, 2011 | 10:33 AM
RPB's Avatar
RPB
Took it to my mechanic who worships my 500, he took nearly two hours of his personal time running all sorts of tests and thought I was loosing my mind! He said the car is sound, but did mention that the ignition wires were orig and that the sparks were recently changed around 56.5k @ the 60k svc. I have heard that the M119 is picky when it comes to sparks, so I might look into this more. He also mentioned that the petrol in the US does not help out and I usually run Exxon or Shell 93.
Old Mar 16, 2011 | 09:25 PM
JSe420's Avatar
1994 E420
Well you can certainly rule out bad VC gaskets because there is no way that would give you an exhaust smell.
I had a similar problem going on with my 420 and it ended up being a fuel pressure regulator so check that out. You could also have a problem with your electronic throttle actuator as someone already mentioned.
Old Mar 22, 2011 | 01:11 AM
Carbooks's Avatar
MG TC
Sounds like the dreaded engine wiring harness to me.
Kind Regards,
Ron
