95 e320
Old Mar 10, 2011 | 03:03 PM
jmscarewe's Avatar
e320
95 e320
I have a 95 e320 keeps stalling after it warms up I've changed wiring harness,cps,maf,throttle body, Overload ralay but it still keeps happening. Does anyone have any ideas
Old Mar 10, 2011 | 04:08 PM
Shoomakan's Avatar
2006 C55 AMG 6 speed
If it's a 95, it should have OBD. Put it on a scanner and see what it tells you.
I'd check fueling since you've covered most of what's under the hood.
Seriously, scan it if you can. It's there to ease such things.
Old Mar 11, 2011 | 09:32 AM
jmscarewe's Avatar
e320
e320 stalling
going to get scan today but I've also changed the fuel filter
Old Mar 11, 2011 | 11:36 AM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
I'm assuming that you have the HFM-SFI engine management.
The problem may be in the control module which can be expensive.
I would test the control module and the three ignition coils.
The HFM control module can recognize combustion problems by monitoring primary current flow in the ignition coil.
If it detects a problem the module will cut off fuel flow to the cylinder(s) so raw fuel won't make it's way to the cat.
Old Mar 20, 2011 | 08:59 AM
Big Dawg's Avatar
1995 E320 Special Edition
What and how do you test the control module?
