C124 Front Window Seal
I have a 94 coupe and when I take it for a wash water seeps in from the front window (pillarless design).
It does so on the drivers side, and at highway speeds there is wind noise from the drivers side window.
I assume the rubber sealing can be replaced?
Is this the main culprit?
Can someone tell me what it is called, maybe a part number etc?
Any help would be greatly appreciated.
Thank you
I've the same issue on my coupe.
I don't have the part number offhand, but I know the seals run a bit on the pricey side. From what I understand, they're very easy to remove and replace though.
Do you know what "pricey" is?
The door lines line up perfectly to the car.
It's quite low mileage and bought new by my dad, never been in an accident etc
The section it leaks from may only be about 5cm or so.
The window closes tight on the rear window as well.
Is adjusting it in this case a good idea?
ie, roughly in the top middle part of the window, and about 3 inches of so get wet and it drips.
I'll take pictures today and post them
