Can I lower on 18's?
Old May 18, 2003 | 02:41 AM
Asmod3us's Avatar
1988 300ce
I just put a set of 18" rims on my car and there is a decent gap. I was wondering if I should have any problems lowering my car, namely with a set of eibach or H&R springs. I am pretty sure the tire size is 225/40-18's, but am not positive. If this would make difference, I can easily get the exact number. Also, if it matters, it would be done to a 1988 300ce. Thanks
Old May 18, 2003 | 03:56 AM
soldsep's Avatar
87 300 E
what kind of rims and whats the offset of the rim?
Old May 23, 2003 | 09:42 PM
badinfo's Avatar
If you have the normal 18mm offset on 18x8 inch wheels, you will probably encounter some rubbing when you drop yoru car, I know I did. I ended up rolling my fenders with a ghetto rigged setup with great success, and the look is definitely worth it.
Old May 24, 2003 | 01:01 AM
///AMG124's Avatar
1994 MB E420 RENNtech
I lowered my 94 E420 with H&R springs. I am running 18x8.5 ET35 wheels and 225/40's all around. For about 2 months I did not get the suspension alignment done. I did roll the fenders all around.
After rolling the fenders, I did not have any rubbing problems. I just recently installed the Renntech camber kit for the rear. After installation was complete, I then had the car aligned. After alignment, I had alot of rubbing on the front where the tires were rubbing against the plastic body molding. After about 2 weeks of rubbing, I noticed that it basically rubbed itself-in and now I don't hear it rub anymore.
Old Jul 15, 2005 | 02:47 AM
Makahveli's Avatar
"88 300CE- First Year Production
What does rolling in your fenders mean?
Old Jul 15, 2005 | 03:09 AM
e32o's Avatar
1995 E320
They roll the fender lips more into the body so it gives the tires more clearance inside the wheel well.
Old Jul 17, 2005 | 04:10 PM
MidniteBluBenz's Avatar
540 6spd
I lowered my 300E using H & R's (which I'm tryin to sell) and I put on 18x8 Carlsson 1/6 Evo's w/ 225-40's and I had a lot of rubbing on full lock turns and over bumps on the highway.
