removing seat bottom and back from frame
Anyone know which bolts to remove to get the seat and back off. Have a seat in bad shape but have another in much better. It's the driver seat and the donner has the seat memory so can not just switch them. IT'S A 1995 e-320
Horace
Horace
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Reach under the front and disconnect at least two wire connectors from the seat base.
Remove the lower trim from both sides of the seat.
A bolt at the rear of the lower seat side should be visible...
Remove from each side
There should be a screw/bolt either side on the front underside of the seat.
Should do it...
