Brake upgrades...
Old May 23, 2003 | 05:13 PM
shakey's Avatar
1995 E320
Brake upgrades...
Dear readers,
After two months of lurking, I've finally registered . Thanks to all the members for getting me up to speed with my "new" car, a '95 E320 with almost 150K miles in very good condition, inside and out.
Everything is stock right now; first things on my upgrade list are a set of BBS 17" RC rims and Falken Azenis ST-115's. I'm digesting all the info on suspension recs, and will gradually decide what to get - with a wife and three young kids I have to make calculated compromises in this area.
I've always been a brake fanatic, and was surprised that there wasn't much info on the boards concerning the Movit upgrade kit; although it is somewhat expensive it looks REALLY good. I'd like to maintain the character of the car, and don't think that the Brembos (although flexible and well-regarded) will fit the bill. However, going with OEM upgrades and adding aluminum brake lines might be the ticket. I saw the cross-drilled and silver calipers on a CLK 55 recently, and they had the look that would be compatible - how do I go about finding if they (or other later model OEMs) would fit under the planned 17" rims?
Old May 24, 2003 | 02:35 AM
Limited Edition 190E's Avatar
2005 CL65 AMG
Those are the C32 brakes that will need to be "reverse" mounted. Do a search on this forum under "C32 Brakes"
Old May 28, 2003 | 12:28 PM
shakey's Avatar
1995 E320
Hey, thanks! Of course I meant to say stainless-steel brake lines - I don't mind reducing the unspung weight but I'm not that crazy.
Old May 28, 2003 | 05:04 PM
Jim's500E's Avatar
You can stay OEM and upgrade to SL600 or 500E 4 piston calipers and the larger rotors.
Stay away from slotted or drilled, unless you wants the looks. Solid rotors provide fine braking on a W124 without motor mods. SS lines are a good idea and provide better feels than rubber lines. I run Ate Super Blue fluid with EBC pads, never a fade problem and plenty of bite...even on a track.
Movit , I beleive , is getting out of the MB brakes upgrade business. The Movit kit my friend has on his E500 required 19" rims....but the Porsche caliper looks real cool behind the Brabus rims.
