Outside Temp Gauge
Old Jun 11, 2011 | 11:09 PM
stormtigers's Avatar
88 W124 300CE
Outside Temp Gauge
Hi Guys
Anyone know whether the outside air temp gauge was standard or optional on 88 300 CE ? Obviously there is something there to fill in the gap but nothing shows on it. I am wondering whether it is (a) broken or (b) not installed ?
I know I could pull the cluster out but waiting for plasma inserts before I do that. But I figure if it is installed and not working I should be looking to buy a replacement.
Old Jun 13, 2011 | 02:02 AM
neanderthal's Avatar
Should be standard.
Edit; For North American cars. I just realised that you might not be.
Old Jun 13, 2011 | 02:25 AM
88 W124 300CE
Hmmmmm Yes true
Originally Posted by neanderthal
Should be standard.
Yep way down the other side of the planet - choking on dust from that damn volcano in Chile ! (not literally but they grounded all flights last night just in case)
I guess I will have to wait until I pull the dash cluster and see if there is any leads going out of that module or whether it is a blank.
Not the sort of thing I would have thought of as "optional"
Old Jun 13, 2011 | 10:12 AM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Do you have the sensor bulb which is located at the center of the front bumper beneath the license plate holder?
Old Jun 14, 2011 | 01:31 AM
88 W124 300CE
Alas no the item is not standard over here - I guess if I wanted to add the wiring etc in I could do it but me thinks "I ain't that brave".
Seems a shame to have a blank lcd screen there though albeit a very small one !
Any suggestions guys ?
Old Jun 21, 2011 | 02:03 PM
E420guy's Avatar
1994 Mercedes E420
I just bought my E420 this past Friday. I have similar issue, mine says -36f when you turn the key but goes completely blank afterwards, leaving me with a lit up, blank, LCD screen. I know mine was in a fender bender somewhere along the line so maybe mine is a sensor related issue..I say just live with out it. or get you one of those newer rear view mirrors that do the same thing. Good luck!
Old Jun 22, 2011 | 01:53 AM
Shoomakan's Avatar
2006 C55 AMG 6 speed
If it is a sensor related issue, just have the sensor replaced. I had the same problem, I'd start it and it would give me -38 degrees Celcius. It was a 10 minute job to fix it.
Old Jun 23, 2011 | 07:50 AM
E420guy's Avatar
1994 Mercedes E420
I actually looked and yeah I have the sensor, I think, it's just some metal looking thing at the end of a thick wire, it looks old, and I see know way to replace it, unless you need to cut back on the sheathing of the wire? Is there a DIY post here somewhere on fixing it?
Old Jul 11, 2011 | 04:47 AM
88 W124 300CE
Restroing this thread - I have one - Now where does it go ?
Hi Guys
I thought I had buried this thread but I want to bring it back to the forefront again if I may. I bought a sensor with what seems a very short pigtail.
Now I know where it goes in the instrument cluster but where do all the wires go is the big question !!!
The harness has
Black
Brown
Grey-Blue Stripe
Yellow-Green Stripe
Green and another brown which the supplier has twisted together with the green and brown from the sensor.
Any clues pictures instructions guys ??
Help me out here Haahahhahahahah
