Um, help? 1988 300E stalling at lights
Old Aug 12, 2011 | 10:47 AM
MidwifeC's Avatar
300E
We have a 1988 300E that runs like a dream.....as long as it's moving at 45 MPH or greater. The problem is it stall out at lights, in heavy traffic, or at long stop signs. If we sit for 10-15 minutes, it will crank right up.
At first, when idling at a light, the temperature gauge would slowly rise to over 90, then stall out. We changed the thermostat, no fix.
Then, after talking to a Mercedes mechanic, he suggested it my be the temperature sender....which we replaced. So, no more slow rising of the temperature gauge, but it still stalls out in slow traffic or red lights.
What else could it be? I'm thinking the continuos fuel injection sender?
Thanks in advance!
Old Aug 13, 2011 | 06:31 PM
ds190's Avatar
300TE, 300CE
Wha?
I don't know what a "continuous fuel injection sender" is. The engine temp rising to just over 90 is not significant imho.
Start basic- the stall at idle, or when coming to a stop, is common when the OVP (Overvoltage protection relay) is going bad. That part wears out, gets filled with dirt, or corrodes to death. If it has never been replaced, it should be done now anyway.
Check that first before digging into the FI system.
Old Sep 2, 2011 | 03:59 PM
Frank Nitty's Avatar
1987 260E, 2008 GL 450,1980 240D 2002 Chevy Tahoe LT
I Had the same problem, my mechanic replaced the computer with a used one and I have invested over $4000.00 more bucks into the car because it runs so well now
