Seafoam help
Old Sep 28, 2011 | 12:06 AM
kodoq39's Avatar
1988 300ce
Seafoam help
Anyone know where do I pour seafoam in 88 300ce. Thanks
Old Sep 29, 2011 | 12:07 PM
Jim's500E's Avatar
Are there no directions on the bottle?
Old Sep 29, 2011 | 01:28 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
You can add it to the gas tank or carefully and slowly draw it into the intake manifold via a vacuum port.
Not sure why you're going to use it....what are your symptoms ?
Old Oct 1, 2011 | 04:27 AM
stormtigers's Avatar
88 W124 300CE
Barnacles on the exhaust manifold ?
Sorry couldn't resist - never heard of the stuff !
Old Oct 4, 2011 | 01:23 AM
kodoq39's Avatar
1988 300ce
I was thinking to 50 in gas n 50 via vacuum line, is the vacuum line needs to be open with a wrench? The one connected to big black round rite? Cuz I did my f150 I just unplug the vacuum line by hand its kinda weird if this 1 need a wrench to open it. Nothing I just hve bad mpg, less power n just want to clean up lil bit
Old Oct 4, 2011 | 03:33 AM
neanderthal's Avatar
So shouldn't you be asking what steps you should be taking to improve your fuel economy?
Old Oct 4, 2011 | 10:55 AM
RBYCC's Avatar
Seafoam consists primarily of naptha which has a strong cleaning/detergent effect in an engine.
It's not a "magic bullet" if you have problems with the CIS-E settings on your M103-12V or even something as basic and extremely common as a vacuum leak.
I'm very basic and logical when it comes to troubleshooting and diagnosing problems with an internal combustion engine.
Why not start by pulling your spark plugs and "reading" them..
The condition of the plugs will lead you to where your problem lies be it fuel, ignition or combustion...
Old Oct 4, 2011 | 11:30 AM
kodoq39's Avatar
1988 300ce
Thx for the advice. I changed my plugs like 4 or 5k ago so I assumed plugs r still ok and the reason I wanna do seafoam cuz I did it with my truck cuz I ran through a problem with it n theres noticable differences at least for myself n since it has 150k on it I thought it wouldnt hurt to clean the inside lil bit cuz I dont hve money to change dis cap etc . Is it bad for the engine if I use seafoam? Thanks for ur reply though
Old Oct 4, 2011 | 01:53 PM
RBYCC's Avatar
When you changed your plugs did you "read" or analyze the condition and color of the plugs that you removed...
I guess "reading" plugs is becoming a lost art on newer computer controlled engines with plugs that go 40K-50K miles.
You're M103-12V is far from an engine that has a high tech engine control system.
In fact your fuel injection is only semi electronic !!
Seafoam is not going to hurt your engine as long as you use it per the instructions...
I wouldn't use it on an engine that has been maintained with regular oil/filter changes and uses a tier one gasoline..
In your case ..go for it !!
Old Oct 4, 2011 | 09:39 PM
kodoq39's Avatar
1988 300ce
Ok I did seafoam to my car and... I dont know why the smoke didnt come out as much as I expected there was thick smoke but thats only like 5 seconds n the rest like almost nothing. Did I do something wrong? Cuz I know my engine cant be that clean
Old Oct 4, 2011 | 11:41 PM
I can hardly understand what you're saying now.
Not bothered anymore....
Old Oct 5, 2011 | 08:01 AM
RBYCC's Avatar
Exactly...
The OP was determined, he did it, engine still runs, but didn't make enough smoke to annoy his neighbors...
"Mission accomplished !"
Old Oct 5, 2011 | 11:36 AM
It's amazing what spelling, punctuation, syntax and grammar can do for a string of letters......
