FS: 3 sets of headlights (2)94-95 (1)500E specific and (1)94-95 tail lights
Old Jan 4, 2012 | 10:28 PM
Dysphoria's Avatar
'89 300CE
Tail lights still up for sale?
Old Jan 5, 2012 | 11:52 AM
funkgab's Avatar
1987 300E, 1995 C280
willing to part led bulbs and housing?
trade for stock? and money?
Old Jan 6, 2012 | 04:11 AM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
I've still got the tail lights. Dysphoria, you aske first so I'll give you 24 hour dibs over funkgab. Do you want the assemblies with the LED setup, or with the standard bulb holders for a more oem look?
If he doesn't want them funkgab, I'll absolutely sell just the LED boards. They're just sitting in my closet. We'll talk $$ if it comes to it. Thanks!
Old Jan 6, 2012 | 09:38 AM
funkgab's Avatar
thanks, let me know.. i already have headlights and inner housing.. do the led boards work with the stock connector? (actually i swapped to 6 pin)
my tailights are a little complicated (their slightly tinted and i was running stealthbulbs for the turn signals)
also in the future i was planning to mod the reverse into a bright white like a modern cts or so.
is it possible to only make the brake and regular lights led?
(probably with some splicing/soldering perhaps?)
Old Jan 6, 2012 | 12:58 PM
Funkgab, the LED portion uses a 6-pin connector, so you will be fine. The factory 7-pin connector on US cars (driver side only) will not fit, so if you've swapped over already, that's great! You will, however, need to swap around the pins in their sockets. You can clearly see which wires go to each light panel on the board, so you'll just need a multimeter to check the pins on your car for each bulb (reverse, running, signal, brake, ground, inner fog). The turn sinal and reverse lights are still regular bulbs, so you should be able to do your cts setup just the same.
Old Jan 6, 2012 | 06:39 PM
Dysphoria's Avatar
'89 300CE
I'll pass on 'em. Thanks though.
Old Jan 15, 2012 | 10:03 PM
  #32
funkgab's Avatar
sweet, ill let you know soon, i was going to purchase it, but a e420 popped up! but if you gotta let em go let em go
Old Jan 17, 2012 | 09:11 PM
  #33
Sold the other set of e320 lights. All that's left is the 500e lights and the tail lights.
Old Jan 18, 2012 | 10:02 PM
  #34
funkgab's Avatar
as in the leds? btw are you doing w124 dismantlement or did you just have stuff lying around ?
Old Jan 19, 2012 | 03:45 AM
  #35
The LEDs are still available if you want them. I'm not dismantling anything, I have just gotten lucky at the local junkyards when it comes to the lights. I actually hit 7 different yards since Sunday!
Old Jan 19, 2012 | 05:51 PM
  #36
funkgab's Avatar
Haha sweet they have any whole cars there?
Ill take some cellphone pics later of my lights and see if they match up with the boards.. I didn't end up buying the car afterall.. Also all usa w124s use the same models right? Although I see lots of japan imports aparently
Old Jan 19, 2012 | 09:09 PM
  #37
Yeah they have whole cars. Tons of them. Feel free to shoot me pics, but I can already assure you they will fit. All w124 tail lights (besides the wagons, obviously) are interchangeable.
Old Jan 24, 2012 | 04:18 AM
  #38
funkgab's Avatar
i meant whole cars as in driveable.. :P i've been looking for another w124 (well a decent cheap one cause sometimes i heard the junkyards have some stuff), (ce.e420,320)
but i know a cheap benz isn't the way to go but i miss it so much and im carless so @_@
not really a fan of the sedan anymore though.. well maybe besides the 500/e420/400
(havn't driven a 3.2 104 yet or a ce yet)
they have german serial # as posted above so i was worried, i bought the lights from 2phast, and swapped out the connectors.. his had some weird 4 or 5 pin (i think? i don't remember) but i swapped the connectors out cause they didn't fit my 87 300e ones
sorry about image size and quality.. i have no idea how to edit them as i uploaded em from my phone to tinypic
~final edit.. oh and im sure i swapped out the reflectors, you know the chrome thing because the facelift ones looked weird with my bulbs
Old Jan 28, 2012 | 02:18 PM
  #39
Funkgab, the part you posted pictures of is completely removed with the LED setup and replaced with the board you can see here:
So yes, it will work fine for ya.
Old Jan 29, 2012 | 03:31 AM
  #40
funkgab's Avatar
sounds great, so let me get this straight, i know my lights are facelift, but the light housing itself i think is a prefacelift.. isn't the led one hooked up to a facelift housing or did you remove it completely and insert the board in?
http://www.youtube.com/watch?v=PKkA2MFAzXs
they light up like this right? since its not using the cheesy aftermarket modern LED wannabe things like this
or do they still kind of light up like that? where it has individual tails?
honestly i just wanted something maybe a little brighter/quicker.. my lights already look pretty good since their smoked lightly but always push the limit :P
btw how much do you want anyways? ill see how much i can budget it out from my car purchase
Old Feb 3, 2012 | 08:52 PM
  #41
The LED replace EVERYTHING except the lens itself. It will work with either face lifted or pre-face lifted lenses.
As for the lighting, it really depends on how you wire it up. There weren't instructions with them when I bought them so I kinda winged it. I had it in a way where the center lights (triangle like ones) were running lights and the rest of the bottom row lit up when I brake.
Old Feb 4, 2012 | 03:30 AM
  #42
funkgab's Avatar
sounds cool.. again how does it light up and price!
Old Feb 4, 2012 | 04:04 PM
  #43
I'm not sure I understand the question: How does it light up? Red? With electricity? Sorry, things get lost in translation on the Internet sometimes.
Price for just the LED portion? I'd say $65+ shipping sounds fair.
Old Feb 5, 2012 | 01:09 AM
  #44
funkgab's Avatar
sounds good.. you mind holding em for a little? i just picked up another w124 so i'm trying to budget everything out first.. well you can sell them if you want..
by how they light up i meant in my earlier posts.. are they like individual leds, or just a couple? or how does it light up? which example does it look like with the regular covers on
Old Feb 5, 2012 | 01:03 PM
  #45
190E 16V's Avatar
1987 560SL
Hi Riv,
Are all the actual diodes red in colour?
I mean, without the coloured lens.
I have some clear tails that would look awesome with LED's
Old Feb 6, 2012 | 12:44 AM
  #46
Funkgab: I said it depends on how you wire them up. The bottom row of lights are partitioned into 3 sections just like stock lights and each section is designated to a certain wire. Depending on how you wire them, they will light up however you want. The picture you posted is likely what the lights look like under braking, not running. You coul make them light up just as the ones in your video if you are so inclined. I will not hold them if someone else has cash, but I've had no other offers.
190e: I never thought to check that! I'll get right on it. Hopefully I'll have an answer in a couple days for ya.
Old Feb 6, 2012 | 06:10 AM
  #47
funkgab's Avatar
yeah let em go if you want, as much as i want them, i have a ton of maintenance ive gotta do
Old Feb 6, 2012 | 11:17 PM
  #48
190E 16V's Avatar
1987 560SL
Thanks Riv
Old Feb 14, 2012 | 03:42 PM
  #49
Got it! The LED diodes themselves light up RED. Does that influence your purchase?
Old Mar 7, 2012 | 02:33 PM
  #50
190, did you see my last post? Tail lights are still available.
