Need Help/Advise Removing RennTech Exhaust
199o 300E, 1993 300E, 1994 E420, 1997 Range Rover 4.6
Hello Guys........... I came across a 1992 400 E with RennTech exhaust at my local Pic A Part yard. I would like to remove at least the muffler/tailpipe to install onto my 1994 E420....... Can Anyone offer advise on approximately where to cut the pipe AND what type of hand saw will i need to cut pipe?? I do have clear access to the hangers/mounts but i dont know what to use for cut Or where to make my "chop" Any Advice/Help/Suggestions is Greatly Appreciated.... Thanks ; In advance,,,,,,,,,,,,,,,,,,Chance
'91 C124 300CE,'06 ML 500 W164, '00 BMW MCOUPE, '65 COBRA REPL.
What I would do, is I would remove the entire exhaust from the headers back.
It will be all bolts, hangers etc to remove, and then just bolt it back on your car. No welding etc and expenses asooctiated with it.
The renntech exhaust could have different diameter pipes, and the whole system designed and built from the headers back.
If it is just the mufflers welded on to stock pipes, go as far ahead as you can and cut.
Then your mufller guy will figure out the rest.
