Engine Serial number help.
Old May 29, 2018 | 04:51 AM
Sag12's Avatar
Ml 320
help please!!!
Help with my engine number vin-4JGAB54E4YA202844
Old Nov 12, 2018 | 05:51 PM
CatalinG's Avatar
Mercedes Benz 207D
Identify Mercedes Benz engine with SN
Hello! I actually edited my post from yesterday, because I realized today that the info and photo I provided was wrong.
I'm the recent owner of a Mercedes Benz 207D that had a motor transplant in the past. All I know is that it's a Mercedes engine with servo and I think it's from a Sprinter 208 or 210. I have the SN but I didn't manage to find out anything about it (capacity, manufacturing year..etc).
So, today while cleaning some oil from the motor I found the small plate I was looking for, right under a small oil spill. I attached a photo with the engine's SN on that small red plate. I'm not sure which one it is.
Doing some research I came to the conclusion that it's an OM601 or OM602 engine. Thing is, that it looks more like an OM602 which has 5 cylinders, but mine has only 4 cylinders - Mine, is exactly like the one from the 2nd picture.
I would really need some help with identifying it exactly so I can be able to order some parts. Thank you so much!
Old Nov 13, 2018 | 11:11 AM
CatalinG's Avatar
Mercedes Benz 207D
I actually just realized that the answer was written on the small red plate it's definitely an OM601 engine - the only thing I don't know now is the capacity, although I think it's a 2.3l engine. Is there a way to find this out online, using the SN?
Old Apr 1, 2019 | 11:37 PM
Ottounyime's Avatar
Mercedes E320
[QUOTE
]Hi, I am also having trouble locating my engine number. my VIN number is WDBJF82J11X060514. any help please?[/QUOTE]
Old May 16, 2019 | 06:34 AM
jeffjerry1's Avatar
GlK 350
I need my engine serial number please. I have the VIN. Someone should help me check
Originally Posted by samdunlap
I found this site and it's pretty cool and accurate: www.vindecoderz.com/
Good luck!
Sam
Old May 16, 2019 | 06:40 AM
jeffjerry1's Avatar
GlK 350
WDCGG5HB5DG026873
Old May 18, 2019 | 11:09 PM
  #32
ohollenbeck's Avatar
04 E500, 00 SL500, 99 SL500, 94 E420, 92 500E, 92 500E, 92 300CE, 06 Lexus GX470
tomorrow
Originally Posted by jeffjerry1
right now the Mercedes Xentry system is down for maintenance, when it comes back on line I'll run your data card
Here ya go: Xentry back on line
Major assembly number Variant Object number
Engine - 27695730305124 A2760109804
Transmission - 72290604499192 2042700605
See Data Card for you car, attached
File Type: pdf
Old Aug 1, 2019 | 05:08 PM
  #33
deeanu's Avatar
1992 400se, 1990 560sel, 1995 e320
SWAPPED ENGINE
Hello I have a 1992 400SE with what i was told to have been swapped out with a 500e engine problem is the alternator went out and now i need to very whats really in the car to get the right part..... Any help would be appreciated...
Old Aug 31, 2019 | 09:32 PM
  #34
Route 50 Motel's Avatar
mb gl550
Driver
[QUOTE=ohollenbeck;7077980]inputting your vin into Mercedes EPC, the engine no. = 272920 30 468903[/QUOT
4JGDF7DE5FA483675 can you please provide engine serial number thanks
Old Jan 5, 2021 | 12:01 PM
  #35
yasit10's Avatar
W211 2006
Engine serial from VID
Hi would you please help to find engine serial for my car here is VIN
WDB2110611A122576
Best Regards
Old Jan 5, 2021 | 05:11 PM
  #36
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
WDB2110611A122576
Best Regards
112913 31 373985
File Type: pdf
Old Dec 14, 2021 | 12:13 PM
  #37
Benzzoo's Avatar
300e
Call Benz national
800 367 6372 and they can look it up by your VIN.
Best
Old Sep 2, 2022 | 02:15 AM
  #38
hunterxninja's Avatar
W124 E280 Masterpiece
transmission model for w124
HI Greetings Sir,
If i may ask the information for my WDB1240286C276544 chasis datacard. Im trying to find the transmission model for my car . I havent yet jack up the car. My transmission has a delayed shifting issue where it takes few seconds to upshift making the rpm higher when i push hard the accelerator ,well it does not seems like a smooth gear shifting. I just bought this car for abouyt a year now and i have rebuilt the transmission for almost 3 thousand dollars in my country curreny. Im currently residing in malaysia. I felt cheated when i spent so much to rebuild the transmissoin yet its not smooth enoughh yet.. i love the car tho..have spent a tone of money on it to bring it back to its glorious days. Please do advice .Thank you so much.
Regards,
Shathish
Old Sep 2, 2022 | 02:18 AM
  #39
WDB1240286C276544
Regards,
Shathish
Old Sep 2, 2022 | 02:57 AM
  #40
khomer2's Avatar
722.433
The price of a rebuilt tranny in NA ranges around $1800-$2500usd (wth core exchange). It could be more $$ in your region.
These trannys are notorious for rear band wear issues so consider yourself lucky that you now have a rebuilt one that should last for many years.
Your issue sounds more of a vacuum leak. Inspect all your vacuum lines and perform a DIY vacuum test to find any leaks. Replace all old lines - this w124 is 27 year old.
You should also check test the vacuum line to the transmission ===> vacuum modulator. Or the vacuum modulator itself may be the issue causing your delayed shifting.
File Type: pdf
Old Sep 2, 2022 | 03:36 AM
  #41
Thank you so uch for information. Will do a thorought check onn the vacuum lines and also the modulator. Have a blessed day ahead. will do update again if it all works in harmony. Thank you Sir.
