1995 mercedes e300 diesel
Old 04-04-2012, 06:37 PM
catdaddy's Avatar
1995 mercedes e-300 diesel
I just bought this car: the tac, the cruise and the a/c dont work. Can anyone tell me how to start troubleshooting to fix these items. To get the car to crank you have to switch the ignition on and back off three times the the fourth time you can go all the way and crank the car. Can anyone help me with these problems!!!!!!!!! Thanks.
Old 04-04-2012, 07:57 PM
chomp_sticks's Avatar
06 E55 Wagon 95 E300 87 560SEC 16 Miata
Are you letting the glow plugs warm up properly?
Old 04-04-2012, 11:24 PM
LawrieMB's Avatar
A Free VW
There is always a difference in how people describe 'cranking.' When you turn the key the first time does the starter turn the engine over but the engine does not start, or does it take 4 times of turning the key to get the starter to turn the engine over?
Old 04-05-2012, 06:49 AM
catdaddy's Avatar
yes, I switch the car on and let the glow plugs warm up 30 to 45 seconds before trying to crank the car.
Old 04-05-2012, 06:52 AM
catdaddy's Avatar
The engine is turning over when I first turn the key, but will not start, so I turn the key on and wait for the glow plug lite to go off each time then after the third try the engine will start.
Old 04-05-2012, 09:44 AM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
Sounds like you are missing your "tach" signal. Since oil burners don't have an ignition system, MB generates one via the Idle Speed Control Module (ISC) which takes a signal from a sensor on the flywheel. The ISC, the A/C system and your instrument tach all require this signal to function, so it's clearly the common element. The difficulty starting may also be related because without the "tach" signal, the ISC system has no way of knowing that the engine is actually running and a what speed.
I would start by checking all of the fuses, but check fuses 5, 6, & 7 in particular. Check them by removing, inspecting, and replacing - I have seen hairline cracks that are electrical opens, but visually look good until you take the fuse out.
Then, visually inspect your engine wiring harness - your car is from the eco-junk harness era, so if it hasn't been replaced, the insulation will be deteriorating. Look for cracked insulation around the engine sensor connectors. Anything and everything can happen/fail with a bad harness.
You may also want to check/replace the OVP relay as this supplies power to the ISC. You can check for + 12 VDC on pin 6 of the OVP with the engine running. OVP failure seems to be a right of passage with these cars.
Lastly, I would look into the speed sensor itself. I don't have the resistance value handy, but it should be in the several hundreds of ohms range. If it's near zero or open, the sensor is bad.
I have attached the engine control schematic for you car in case that is helpful.
Good luck.
File Type: pdf
Old 04-05-2012, 02:01 PM
Former Vendor of MBWorld
ALLDATAdiy INFO's Avatar
Mercedes
If you get stuck checkout ALLDATAdiy for diagnostic and repair help.
Quick Reply: 1995 mercedes e300 diesel
