valve noise come and go
valves are noise when engine is hot.Help... Does anyone experienced this problem, a knocking sound on the valve assy when it was driven for about 30 mins. When the engine cools down and then restarted it seems to be quite.
Elie
Back ground on this car, the car was not used for a long time and the engine oil was dirty. I flushed it twice. Then change oil. I used castrol 40. I also replaced spark plugs.
The engine has power it can hit 65 mph easily.
Thanks in advance
elie
300E 114,000 miles
1986..
Are you sure it's the lifters and not something else?
I think MBZ started using hydraulic compensators on 3.2 DOHC engines, but I may be wrong on that one.
Arnie.
Anb BTW I can't think of anythung that would case that noise.
There is a remote chance that the gaskets between the muffler manifold and the engine block are burnt. If so this also causes "ticking" noises, which come and go. Hard to test since they tent to burn on the lower side you cant see w/o holding a little mirror underneath the manifold. To swap those gaskets is quite a job for a DIY since the manifold has to come off from the catalytic converter onwards. The nuts tend to be burt in badly, and the bolts should also be replaced. Partswise no big deal but timewise.
Have it machine and it is fixed.
