Sunroof will not tilt, how to fix
Old Jun 2, 2012 | 12:22 AM
Big Dawg's Avatar
1995 E320 Special Edition
WE320 sunroof will not tilt. It will open however. Any advice as what to check?
Thanks in advance.
Old Jun 2, 2012 | 01:28 PM
ds190's Avatar
300TE, 300CE
Lifting arm
There is a pair of lift arms that sadly break. Difficult but doable repair. Look in the FSM or use Search above to find threads to repair. There is definitely a thread at peachparts dot com & likely one at benzworld dot org.
My TE sunroof lifts with a creaking sound, so I don't use that position. I only open straight back until I can replace the lift arms.
Old Jun 3, 2012 | 04:29 AM
lowesguy's Avatar
124 92 126 90 R129 91
Same on my 91 w124,looks like a ***** to fix from what I've read,but need to fix eventually
Old Jun 3, 2012 | 04:58 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Courtesy of AmgDave:
http://okiebenz.com/pipermail/merced...ry/027261.html
I used that DIY to successfully repair my own sunroof.
