1994 Convertible - Soft top question
I am helping a friend with his W124 e320, and having fixed the majority of the issues with the soft top mechanism, we are now looking for the missing/broken parts associated with it.
One of these parts is the plastic handle/grip that is located in the center of the forward arch of the soft top, which helps grab and pull the top down when it is being closed.
The handle was broken when my friend bought the car (along with 50% of the other interior plastics) and he threw the pieces away instead of keeping for reference. Would now want to get this piece but I'm having a hard time finding one for sale as I don't know the part number.
Can anyone help with this?
Thanks in advance,
Andres G
Fair warning, not every part is available, and most are black so you may need to respray them if your car isn't a black interior car.
Now to the next question: With the top folded down, the hole where the rear bow of the soft top latches in is visible and has no bezel or surrounding plastic cover... is there a part number for this?
Thanks,
Andres G
I will take a few pictures and post them here. Hopefully, this will give you an idea of the parts needed.
Please give me until later today.
Thanks,
Andres G
This is the side panel that hides the seatbelt extender mechanism. The tabs are broken and it has been glued (poorly) to the interior panel.
This is the A-Pillar interior cover. It has been torn on the bottom side (see second picture). This one can probably be fixed easily, so no big concern there.
The headlight switch has some issues I am sure... Turn it to the first position to the right and headlights come on together with fogs. Also, high beam doesn't work.
Rearview mirror surround has parts missing.
Headrest adjustment button on passenger side is missing.
Both driver and passenger side covers for the sunvisor mounts are broken/missing.
Passenger side seatbelt extender hole molding is missing (I though this was somewhere inside the car, but I can't find it.
Trunk mounted 3rd brake light is faded and does not work.
This is the missing top latching hole cover.
Driver side backrest release button suround is missing.
Finally, my friend tells me the oil pressure indicator tends to stop working every once in a while, and that it will come back on by tapping on the instrument cluster...
Would this require a complete new cluster, or would it be best to change just the three gages on the left instrument?
Do you have any of these parts? If so, can you gimme a price for each?
Thanks,
Andres G
Don't even try to take them out as they are brittle and will fall apart.
Your pieces don't look to bad and appear that you can fix to the inner panel with high strength trim adhesive.
Not only were my tabs broken but I had to rebuild the top curved edge with plastic specific two part molding epoxy..
I ended up wrapping them in place with MB-Tex..
The thickness of the MB-Tex fills the gap and is held to the inner trim with a high strength 3M trim adhesive.
I'll take finished pix next time I "visit" my coupe...
Ed A.
P.S.
You can see in the below pic the initial step of filling cracks and rebuilding the top edge....
The plastic handle/grip that is located in the center of the forward arch of the soft top, which helps grab and pull the top down when it is being closed.
Joef, I will send you a PM to see if you have any other parts available.
I have a beauty but the tools are gone and I like to have a wrench for emergencies.
Thanks kmoradpump
