Hesitation @ 3500 rpm
The 104 is DOHC engine. does it have variable timing/valving?
I also notice a bit of a vibration at idle - could be bad engine mounts or the same cause of the hiccup at 3500.
Any ideas?
TIA
Omar.
It can be anything from engine settings to motor mounts.
Motor mounts would be more noticeable if you slowly rev the engine in park from idle.
If the engine smooths out when you do this then my guess would be engine idle settings.
The M104-24V has an "on-off" cam timing but around 3250-3500 rpm you have the addition of a variable intake flap which when it operates can give a feeling of slight hesitation and then power surge.
This is noticeable and normal unless you have a severe hesitation
I think my next step is to change plugs, wires, and maybe even the coils.
Aside from those, and maybe cleaning the MAF, any other suggestions?
Let's start all over again with a single focus.
The only thing that happens at 3500RPM is the variable intake or resonance flap. It may also cause a slight rough idle.
If your read your codes that may help ( www.w124 performance.com/.../DTC_List_W124_M104.pdf )
Easy to locate and service, held on with four allen screws...check to see if it is operating properly.
Since I can live without cruise control till I get around to it, I haven't messed with it.
I'll report back what I find.
Thanks again
Omar
Have you checked the condition of the wiring in the area of the intake assembly?
These cars had the bad wiring harnesses from the factory.
You may have to open up the harness to check for bare wires.
Check for vacuum leaks in the same area ?
On the self-test button on the connector (which matched up with PIN3), I got fault code 6 - Idle Speed Control Inoperable.
PIN 8 - one flash (No Malfunction)
PIN 14 - I got code 3 / 6 / 14.
3=EA/CC/ISC (M16/1)
6=Starter Lock Out/Back Up Lamp (S16/1) **note sure if this relates to my car.
14=Closed Throttle Position Contact Switch (S29/3)
Not sure what all this means yet. And I'm not sure what the code in parentheses means.
Any ideas?
Thanks in advance.
Omar.
PS I hope we all have a great New Year!!!
It may be fine but a bad harness will cause false codes and erratic operation.
The numbers in parentheses are the component designation as appears on the schematics.
First check the wiring as possible you still have the biodegrable engine harness.
Look for insulation breakdown on exposed wires but also peel back the harness wrap.
Is there a cleaning/maintenance/test procedure for the EA and the electronic throttle?
This may help you to dismantle and clean:
http://www.google.com/url?sa=t&rct=j...55534169,d.dmQ
