Lowering a 94 E320 Wagon
Old Aug 26, 2003 | 10:33 PM
Brandon24C's Avatar
2000 C28 Sport
Hi, I am planning on lowering my 320 wagon w124 and I was wondering if you guys know who makes suspension kits for this car. Are there coil over kits? What is the ride quality like? Any help would be greatly appreciated. Thank you!
Old Aug 27, 2003 | 04:22 PM
Brandon24C's Avatar
2000 C28 Sport
Does anyone have any information on this?
Old Aug 27, 2003 | 09:32 PM
Greg in Oz's Avatar
350SLC, 500SLC, 300TE, 190E 2.3 Sportline
Many believe that despite the expense, a complete factory Sportline suspension conversion is the way to go due to the predictable outcome. Bear in mind that being a wagon, yours will have the self levelling, hydro-pneumatic rear suspension.
Old Aug 27, 2003 | 10:17 PM
rostov's Avatar
2016 GLE 450 Coupe
Front springs - 124 321 29 04
Rear springs - 124 324 28 04
Front sway bar - 124 323 68 65
Front inner sway bar bushing (2 each) - 124 323 45 85
Front outer sway bar bushing (2 each) - 124 323 51 85
Rear sway bar - 124 326 19 65
Rear sway bar bushing (2 each) - 124 326 01 81
Front shock absorber - 124 320 64 30
Rear shock absorber - 124 320 23 31
Old Aug 27, 2003 | 11:26 PM
Brandon24C's Avatar
2000 C28 Sport
Does this mean that the self leveling suspension will not work if I lower the car? Thanks for the help, it is greatly appreciated!
Old Aug 28, 2003 | 12:02 AM
Greg in Oz's Avatar
No. Just that you need to be aware of exactly what is needed to do the job properly. I don't know which parts, if any, in the rear suspension of the wagon are different in the Sportline. Rostov has quoted some part numbers but I don't know if they all apply for the wagon. For example, rear shock absorbers are quoted. The wagon does not have rear shocks or dampers as such, but instead has hydraulic struts. The softer rear springs carry most of the base load and the struts carry the rest and the extra due to loading. You also have air cells or accumulators with the self levelling rear end. Again, I don't know if these need changing. If some of these do need changing it could become a costly exercise. One thing I do know is that it is not acceptable to simply adjust the rear self levelling ride height for a lower ride. This will simply cause the self levelling to become ineffective and may even cause damage.
Old Aug 28, 2003 | 12:52 AM
rostov's Avatar
2016 GLE 450 Coupe
Greg is right about shock absorbers, but Bilstein should have the right hydraulic struts for it. At list there is an exemple of it in Bentley's manual.
Old Aug 28, 2003 | 12:58 AM
Brandon24C's Avatar
2000 C28 Sport
Thank you very much for the help!
