91 300CE - warm starting problems
Old May 6, 2013 | 07:44 AM
BillNCoupe2's Avatar
From: Peekskill, NY on the Hudson River, an hour north of NYC
1991 300CE
91 W124 300CE 24V (80K miles) starts fine from a cold start. When driven & then try to restart from a warm engine, car is difficult to start (bucks & stalls) & requires tender foot on the accelerator to gently get it to smooth out at 1500-2000 RPM for about 20-30 seconds before releasing accelerator & then is fine again. drives fine afterewards. any thoughts plz??
Old May 9, 2013 | 07:27 AM
stormtigers's Avatar
88 W124 300CE
Check Idle Control Valve
Check Duty Cycle /Mixture Ratio
Check for Error Codes
Old Oct 9, 2013 | 06:42 AM
dons551's Avatar
300 CE 24v
Similar issue - cutting out on short journeys
my car is expressing a similar problem it will start and drive fine from cold albeit a longer journey than 2 miles. If it is a short journey like just to the shops i have a problem when i get back into the car and start it. it more than likely starts fine but when put into gear and i press the accelerator pedal it will cut out for some strange reason?
I have to let the whole car cool down again for that same short journey? is this something over heating perhaps. It is quite a pain and getting really annoying now. I have shown it to several mechanics who do not know what it can be.
I have changed many thing on the car hoping it would solve the issue but sadly all to no affect.
Any help guys?
Old Sep 21, 2024 | 11:25 PM
shekinahhh's Avatar
2000 E55 amg
Any help guys?
To anybody with the same problem, I know this is an old post but...this might help - mine was doing the same thing, it was the voltage regulator. Cheap and easy fix.
