Knocking noise from the front end...
Old Aug 27, 2003 | 10:19 PM
rostov's Avatar
2016 GLE 450 Coupe
Hello,
I have 1994 E320.
I am getting a knocking noise (not loud) from the front at ~ 30-50 mph. The density of knocking is related to the speed and it's faster then wheel spin. I have new front brakes (rotors/pads), new struts; There is no play in the steering wheel and the rest of the suspensions looks good.
Another thing, I am not sure if it's related, - the speedometer arrow is jumping in tact with that knocking (I think).
What could it be?!
Thank you,
Val.
Old Aug 29, 2003 | 11:35 PM
Jer's Avatar
Jer
1994 E320
The knocking could be a worn front flex disc. It couples the transmission to the drive shaft. Replace it soon!
The speedo needle jumps at low speeds (around 0-30 MPH). This is typical for the older VDO mechanical speedos.
Old Aug 30, 2003 | 08:27 AM
rostov's Avatar
2016 GLE 450 Coupe
Thanks Jer,
I will check it!
Old Aug 30, 2003 | 08:32 AM
Jackd's Avatar
260E , 1989 (for now)
it could also be a defective speedo. cable making noice.
jackD
Old Aug 30, 2003 | 08:37 AM
rostov's Avatar
2016 GLE 450 Coupe
Yes, but my noise is too heavy for the cable.
Old Sep 4, 2003 | 11:28 AM
MBZ12's Avatar
'07 R350. '05 C230. '93 454SS Truck. '71 Chevelle SS.
You should have your harmonic balancer checked also....just a precaution. JJP
Old Sep 4, 2003 | 11:40 AM
rostov's Avatar
2016 GLE 450 Coupe
It has nothing to do with the engine - I tried to turn engine off while driving....
Thanks,
Val.
