Heater Problems
If you car does not have the dual setup, when you say "no heat", do you mean no air flow or air flow that is cold?
If you mean no airflow, Plutoe is correct. The left and right heater outlets each have their own damper. These are connected together via a linkage behind the radio. If you take the plastic outlet covers off in the footwells, you should then be able to lie on your back in the footwell and see with a flashlight if the dampers are open or closed. The linkage may have broken, leaving one of them closed.
