electrical surge
Old Jul 31, 2013 | 12:50 AM
royvotava's Avatar
1990 300e
electrical surge
Ok so my 23 year old car decided it wants to develop an electrical issue. I noticed that when the car is running that my lights,both headlights and dash lights dim and then brighten again.it also makes my amp kick on and off.the system is not the issue as it does it even with the system out of the car.I have a good battery and alternator.I have good grounds between the engine and chassis.no bare wire that I can see.so what do I need to look at next? Anyone ever had this problem? Its my families only means of transportation so I need to get it fixed.any help will be appreciated.
Old Jul 31, 2013 | 02:36 AM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
Roy -
A couple of suggestions:
Check/replace the voltage regulator - it could be intermittent so the alternator "tests good", but the regulator can't maintain a constant output.
Check the alternator wiring harness very carefully for deterioration. Degradation is a known problem.
- FD
Old Jul 31, 2013 | 12:52 PM
royvotava's Avatar
1990 300e
Originally Posted by Floobydust
Roy -
- FD
Thanks for the input. I was thinking about the voltage regulator myself. If the wiring is degraded its not in a place that can be seen.ill be putting a new regulator on it tomarrow and let you know what happens.
Old Aug 12, 2013 | 11:13 PM
royvotava's Avatar
1990 300e
Yep voltage regulator fixed it but now my tranny went out.this sucks. Will one from a 91 bolt right in and work?
