E320 W124 ABS light stays on
- FD
I noted that your profile says you drive a 400e, but the title of your post simply says E320 W124, so I am assuming that we're talking about a a 6 cylinder car here. I have posted the diagnostic connector functional pin outs for 8, 16, and 38 pin connectors. On the 8 or 16 pin connectors, pin 6 is the SRS (Airbag) pulse code output which will not be relevant to an ABS problem. Pin 6 is, however, the ABS output on your 400e which will have the 38 pin connector.
Follow the troubleshooting guide in the PDF and see what you come up with.
- FD
Thank you so much for the information. I am still digesting the Mitchell information you sent. Indeed, I have the 400e with 300K miles on it. I recently got a 320. I wish I can get the ABS tester to do the job right.
Phat
Two more suggestions. One, be sure that all of your fuse contacts are cleaned and that the fuses are each removed and inspected (preferably replaced). Two, check your OVP relay - if you are not familiar, it is located behind the battery and has one or two blade style fuses located under a plastic cover on it. Be sure that (those) fuse(s) is(are) not blown. The OVP supplies power to the ABS solenoid relay and no-power to this relay is what causes the ABS light to come on (via a blocking diode).
- FD
My other E320 has a different ABS problem. the ABS light will come on after about 20ft of driving. It is consistent. I have checked the front speed sensors. They have 1600 Ohms, and they generate AC current when the wheels are turned. The rear sensor has 700 Ohms, I have not checked the current yet. This is the car that I borrowed the ABS module from. So the module works OK but somehow it gives ABS light when driving. Thank you in advance
If the sensors or hub teeth are dirty, the signal amplitude can be reduced. If there is excessive wheel bearing play, braking forces can pull the hub teeth away from the sensor, increasing the magnetic path length, and potentially lowering the output voltage below the threshold voltage. At low speeds, there is not enough braking force to disturb the path leng
I would:
- Clean the front sensors and the teeth on the hub
- Check/adjust the wheel bearing play
- Inspect the plastic on the ends of the front sensors - replace sensor if it is worn through (can allow moisture in and can allow metal-metal contact with the hub teeth which can distort the output)
- FD
Phat
No, there should be no metal showing. The sensors are designed to be sealed so that water can't get in and short corrode things. Add this to the flood status, and I would say the sensors are very suspect, even if the resistance measures okay. A few shorted windings can really reduce the voltage output while still measuring okay on a DC resistance test.
The wear of the plastic covering occurs when the gap between the sensor and the hub teeth gets too small. The two causes that I know of are excessive wheel bearing play or foreign material building up on the hub teeth or sometimes the sensor. Again, the flood history may come into play as the hub teeth may be severely corroded. Even if the sensor is still good, the excess iron oxide between the teeth will significantly reduce the voltage output from the sensor.
I would start be inspecting/cleaning the hub teeth. The only way I know to do that is to remove the caliper, rotor, and hub. Once you have the hub off, use a wire wheel to clean up the teeth. Then see what happens. If you still have the problem, I would then suspect the sensors.
- FD
- FD
