Cabriolet Wheel Problem
Old Nov 16, 2013 | 05:01 PM
jezinbris's Avatar
1994 W124 E320 Cabriolet
HELP! - I have a W124 E320 Cabriolet and after doing a lot of research on wheels, I am still confused...The main problem is my front wheels have the 4 piston calipers...
Question, will these wheels fit?
A2204010302 Listed as "5 Hole Disk Wheel". Size 8Jx18H2 ET44, PCD 5-112mm
Old Nov 19, 2013 | 09:15 AM
3hrtour's Avatar
Hello I am not an expert either but I just changed out my wheels, springs and shocks.
withthe new front shocks... which i think were alittle larger had to add a 5 mm spacer for the front to have a 7.5 wheel fit the original was 7 inch. I have a 95 e320 cab.. same car... i think
Old Nov 19, 2013 | 03:48 PM
jezinbris's Avatar
Thumbs up Wheels
Thanks for your Info 3houtour....
Yup, you have the same car..... This has been a nightmare, and have decided to have wheel spacers made to suit...
Will throw up some images in a week, once I get my car back from mechanics
Cheers
Jez
Old Nov 19, 2013 | 06:28 PM
3hrtour's Avatar
Cheers
Jez
you should not need to make them just look online mine came in a kit and were a perfect fit... not all are I paid about 130 for all 4 make sure to get the right lug bolts as the u need longer ones now
Old Nov 20, 2013 | 04:30 PM
YNVDIZW124's Avatar
lots of cars
These are from a S-Class, you'll need conversion bolts 14mm seat/ 12mm shank or else they'll vibrate on the freeway. You just need 10mm spacers up front, You don't need spacers on the rear, the w124 can handle up to +45 offset.
