M159 6.2 V8 in a W124?
Old Mar 30, 2014 | 08:41 PM
W124E63's Avatar
W124 230E, W124 E280, W116 280SE
Hi guys im new and ive been wondering about an engine swap from a 1986 230E to a 2011 C63 engine. What else do i need like ecu's, rear diff, modules etc? Ive got a car workshop of my own so i have all parts possibly needed to do the swap. Thanks
Old Mar 31, 2014 | 08:12 PM
Argus Panoptes's Avatar
1990 300e, 1985 635csi
If you have the ability to do the swap, Id swap it into a v8 w124. If I remember correctly the 400e/e420 and the 500e (of course) have an entire upgraded subframe to handle the v8. Of course you'd also need the wiring harness and gauge cluster for the m159.
Old Mar 31, 2014 | 10:33 PM
W124E63's Avatar
Thanks for the tip. Would it be worth doing the install on a W124 ce? i do prefer the sedan but would the ce be an easier install?
Old Apr 1, 2014 | 10:07 PM
autoworrks320's Avatar
93 500e. 15 GLK 250
w124/e63
You would be better off getting a 500e for all the modifications you wold need to do. Actually you would likely be able to pick up TWO 500e's for less $$ than what the swap you want to do would cost!
Old Apr 2, 2014 | 04:37 AM
W124E63's Avatar
What are the differences between a 500e chassis to a 230/280/300e chassis? And since those engines were cast iron block, shouldn't the M159 block (aluminium alloy) be somewhat (as) lighter? So I wouldn't need the 500e chassis. Mainly because I've got a 230e in perfect condition and I'd just like a beefy v8 under the bonnet.
Old Apr 6, 2014 | 08:27 AM
pwogaman's Avatar
85 300SD, 80 280SL, 90 300TE 4Matic, 90 300D 2.5 Turbo, 91 300E 4Matic, 92 300D 2.5 Turbo, 87 300TD
It might be helpful to read through this link. http://www.benzworld.org/forums/w124...fferences.html
Old Apr 8, 2014 | 12:44 AM
Iworkit's Avatar
E430 S430
Mercedes and porsche partnered
You can pick up a more then decent 500e for 10k. Plus Porsche and Mercedes engineers collaborated together to construct this specific vehicle. If I'm not mistaken primarily all the suspension components were put together by porsche. Also the vehicle it self was extensively lighten then the avg w124. All in all Man!! What a pair of ***** does a 500e haul!
Old Apr 10, 2014 | 11:15 AM
Jim's500E's Avatar
The 500E is no lighter than a regular W124, btw.
The .036 chassis is just a modified W124 chassis. You can pound out the regular W124 firewall and tranny tunnel easy enough like they did to the 500Es ....you would have to do prolly just as much modding to get a M156 into the 500E anyway. There's actually a picture floating around of a stripped 500E with a M156 fitted in the engine bay recently. So, anything can be done if you have the drive and the donor parts.
Do the swap on a coupe, or even a wagon IMO. Also a good idea would be to use the W124.034 400E/E420 cars. But of course, if you have a beat down 500E lying around then by all means do it to it. No law against that.
Old Apr 29, 2014 | 10:41 PM
W124E63's Avatar
So your saying that the 400E/E420 would be a better option to swap it into rather than a 500E? Doesnt only the 500E have the Porsche mods?
Old Apr 30, 2014 | 08:23 AM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Porsche didn't do any "mods", they just assembled the cars for Mercedes...
Mercedes only contracted Porsche to do this because Porsche had fallen on hard times and it was to help them get through this rough period.
The design and parts that made the 124.036 were all Mercedes.
Nothing unique about the 124.036 parts that preclude fitting to any 124.
The suggestion to start with a 400E/E420 is purely a financial one.
Less costly than even a ratty 124.036 yet it still provides the V8 cross member and inner firewall that you would have to add and or modify with a I6 car.
You'll probably redo suspension so why pay a premium for a 124.036 that may have a tired factory suspension
Keep in mind to install a V8 that's not a M119, you will have to "engineer" the suspension to match the motor output that you are installing.
You may also have to modify the engine bay to best fit the new engine, but starting with a V8 bay is much better then starting with an I6 bay.
Ed A.
Old May 1, 2014 | 06:44 AM
W124E63's Avatar
Thanks for the great info. How much would an 400E/E420 cost me these days? (Im from New Zealand (bottom of the world) and even e400's are rare over here lol).
Also i was reading that the 500E's rear suspension is the same as a S124 which i also have. Could i replace my current rear suspension with that one if i wasnt to go out and buy a W124.036? Since they are the same?
Old May 1, 2014 | 07:41 AM
RBYCC's Avatar
If you intend installing a M159 6.2 then the last thing you want to do is to install/replicate a suspension that was designed thirty years ago for much less power at the rear wheels.
You don't want the complications of rear SLS.
The simpler the better to handle high torque.
Chassis will have to be stiffened as well as bracing top/bottom struts/shocks.
Based on your questions, I'm not sure if you should go forward and attempt the engine installation.
It will require much mechanical and electrical knowledge and skill to get the build anywhere near satisfactory.
Not trying to dissuade you, just asking you to be introspective about your capabilities.
Ed A.
Old May 2, 2014 | 02:02 AM
W124E63's Avatar
Thanks mate,you are very truthful and i respect that But it would still be a project id like to pick up latter in life. If not sooner
Old May 2, 2014 | 07:46 AM
RBYCC's Avatar
Go for it....
Not going to be easy and it will be a tremendous learning experience.
If you have the time and the will and obtain the expertise then it can be worth it..
Good luck and post your progress
Ed A.
Old May 2, 2014 | 10:12 AM
W124E63's Avatar
Yeah thanks for all, just got to get my hands on a wrecked or salvageable C63. It aint going to be easy as you said but ive got enough will power to go with it aha. Ill post it soon in a new thread.
E63.124 here we come
Old May 5, 2014 | 04:58 AM
WDB124066's Avatar
1996 E320 Sportline Cabriolet x 2
Where are you in NZL...?
http://www.trademe.co.nz/motors/used...-721056029.htm
Old May 6, 2014 | 09:48 AM
Jim's500E's Avatar
Porsche did modify the intake runners on the M119 for the 500Es....that's the reason it has more torque than the base SL motor had.
I will say that a complete and decent .036 will be worth money down the road and it would be a shame to 'cut' one up, just my opinion here. I bet even a turd .036 in the future will be worth good money for restoration as well.
400E/E420s are more plentiful and downright cheap to get into (not sure about your neck of the woods tho)...and they will have the engine firewall all pounded out for the V8 swap already.....and without the self-leveling out back which should be deleted on a .036 with this kind of swap.
Old Jun 2, 2014 | 04:07 AM
W124E63's Avatar
I live in Palmerston North with the often rare W124 drive past.
