E320 cabriolet roll-over bar not extending
Old Apr 29, 2014 | 09:01 PM
CraigS's Avatar
W124 E320 cabriolet
I recently bought a 1993 E320 cabriolet and I cannot get the roll-over bar to extend. The top works normally, there are no warning lamps flashing, the hydraulic fluid reservoir is on the full mark and doesn't appear to leak. I have tried holding the UP switch for up to 30 seconds and I have checked the fuse.
The only thing that happens when I press the up button - either the dash or rear seat switch is that the soft top cover panel raises slightly - 10mm or so.
Any thoughts on where to start ?
Old May 1, 2014 | 06:36 AM
CraigS's Avatar
W124 E320 cabriolet
WDB1240662C017689
Old May 1, 2014 | 08:22 AM
CraigS's Avatar
W124 E320 cabriolet
Thanks. Can you suggest a pulse counter, say on eBay, that I can purchase ? I have no idea what I am actually looking for, and I presume the probe will need to be a specific size for the terminals.
Old May 5, 2014 | 04:36 AM
WDB124066's Avatar
1996 E320 Sportline Cabriolet x 2
Your local Dealer will be able to read the fault codes for you....
