Drivetrain question
Old Dec 19, 2003 | 10:04 AM
jonS's Avatar
Drivetrain question
Hi,
Does anybody know of possible drivetrain issues which can cause vibration at low (5-10mph) or high speed (40+mph)
I have recently replaced the front driveshaft coupling, to try to remove a light clunking sound heard sometimes when shifting down at low speeds. This mostly remedied it, but it still seems as if something is still not quite right.......
A tricky problem which is hard to illustrate to a mechanic.
ANY ideas or notions RE this would be really cool.
Jon.
Old Dec 20, 2003 | 07:19 PM
zeronero's Avatar
Mercedes-Benz 400E
Could be the engine mounts.
Old Dec 22, 2003 | 08:53 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
In addition to zeronero's comment, check the gear box mounts carefully. If they are worn (which is a certain weak point in the manual shift W124) the alignment is distorted and causes noises and resonances in the drive shaft.
Old Dec 30, 2003 | 04:18 PM
jonS's Avatar
Thanks a lot guys,
I will check these out....
do you know if it is expensive to replace these mounts (labour intensive?). And does it require specialist attention.
thanks again
Jon.
