Backing plate?
Old Jan 8, 2004 | 12:10 AM
HeadTurning400E's Avatar
400E (177k)
Backing plate?
Hello,
Today i noticed that my car had a noise coming from the rear left wheel. I took it to my mechanic, and he said that I needed a new backing plate. I was wondering if anyone would happen to know what a backing plate is, and where I might be able to find one for my car.
Thanks in advance
Old Jan 8, 2004 | 12:29 PM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
OK, trusting his diagnosis, it is the plate behind the rotor to which the parking brake shoes attach. Usually less than $50 street price. Funny that your mechnic thinks that this is the problem, usually just putting in an ebrake kit cures this noise...
-D
Old Jan 8, 2004 | 01:19 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
Interesting.... I recently was getting noise from a rear wheel in my 95 E320. It turned out to be the backing plate rubbing against the wheel. Took the wheel off and repaired the problem with a few well-placed hammer hits. I don't know how it got out of place. I wonder if your problem is related.
Old Jan 12, 2004 | 04:55 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
The noise from the backing plate is of a grinding nature since it is the plate rubbing against the hub, due to corrossion. If you clean it and straighten it, the noise may go away for a while. If it needs to be swapped it is a cheap part, very expensive to replace, since the whole brake assembly and the hub has to come off. I changed mine just cutting the plate in two halves and did not have to disassemble the hub, but only the parking brake assembly. After finishing the job I riveted the plate, and it works perfectly since years.
