Improving Fuel Economy on a 1987 Diesel
Old Jan 13, 2004 | 12:08 AM
JaredJohnson's Avatar
1987 Mercedes 300D Turbo
I have a 1987 300D and it gets around 24-26 mpg.
I have been getting these kind of numbers for the last 18 months or so.
I used to have another 300D exactly like it, and it got around 26-28 mpg. It even had more miles on it (235000 vs. 185000), although it had a smoother transmission.
Does anyone know if there is some simple adjustment I can make to play with the fuel economy.
I use delo 400 sythetic, change the fuel filter (and diesel purge) regularly, and change the air filter regularly.
I think I remember reading something about sending more fuel to the engine in this car to make it a little faster off the line. Can you do the same thing in reverse and improve the fuel economy a little?
Any information would be appreciated.
Old Jan 13, 2004 | 12:35 PM
Diesel's Avatar
Mercedes 2019 AMG S63, 2015 E250 Bluetec. Previous: '18 E63S, '07 E63, '10 S550, '15 S550, '10 GL350
Hi,
Does your car still have the trap oxidizer in it?
Old Jan 13, 2004 | 02:16 PM
no
I had the dealership change that out on my other car, but when I purchased this one it had already been done.
They actually replaced the turbo on my other car too, but I don't think that any of that really changed the fuel economy too much.
Old Jan 13, 2004 | 04:42 PM
pifcat2's Avatar
300TE / 300E / 300CE
Looks like you've done the basics. I assume the engine is perfectly tuned. Consider reducing any friction sources: repack all bearings and cv joints : Replace lubricants at tranny and diff.
Other mileage improvement tricks are pumping up the tires on the high side, remove unnecessary items of weight in the car, maybe add a front air dam.
I am surprised you only get as much as 28 MPG. I would expect a diesel to get significantly more than a gas motor. I can get as high as 22 MPG with a performance motor and I've heard of some getting 25 MPG. I guess the savings is mostly in the cost of fuel.
Old Jan 13, 2004 | 04:56 PM
I was under the impression
I thought that the 300Es that were my cars same weight and same displacement got around 18-22 mpg. I think 25% mpg improvement is pretty substantial.
I was looking on fueleconomy.gov and they have my car listed as 25-30 mpg. That was about what I got in my old car, but not in this car. Maybe when I change the transmission it will get better.
BTW, the 24-26 mpg figure is what I get delivering pizzas , but on the freeway it still barely hits 27. I would like to see an 87 300E get 25 mpg delivering pizzas....
Old Jan 16, 2004 | 12:23 AM
Diesel's Avatar
Plug in the block heater during the winter months. You won't have to idle and wait for it to warm up. That will save you a lot of diesel (and wear and tear) as well. And it will save you the embarrasement of others looking at you as your car makes all that noise on a cold start. I once had to explain to this lady what a diesel is after making a cold start. She came up to me and said "you really need to get your car checked out". How embarassing....
