190E 2.6 oil leak
I am buying a 1992 190E with a 2.6 litre. I can see it has an oil leak. I haven't looked closely but my research tells me it is likely a head gasket.
Has anyone had this problem? Will it get worse?(it is minor at this time)
Is it just an external problem, or is there internal leakage as well?
Are the heads susceptible to warpage, or is it simply a matter of replacing a gasket.
Many Thanks
1) front/right side of engine: Most likely the front cover seal/gasket. Faily minor (in terms of $$$) to fix. Some shop won,t do this job without also replacing the head gasket.
2) Head gasket: Normally back/right corner of engine. More major ($$) job. when this job is done, the front engine cover has to come out anyway, so this seal is redone (See No.1)
If you have the head gasket replaced, it is advisable to have a serious look at the valve guides while the head is off. If over 100,000mi, these probably show some wear. If not, at least replace the valve seals.
good luck
jackD
Kisha
