intermittent missing
Rating: Thread Rating: 16 votes, 5.00 average.
Old Feb 24, 2004 | 09:51 AM
qdessa's Avatar
I just got a 95 320 wagon ( to replace the 87 300D that was smashed ).
It runs fine except sometimes it idles rough - it seems to be missing. This condition occurs intermittently and is independent of engine temperature.
There is no check engine light.
Any help is appreciated.
Alan
Old Feb 24, 2004 | 02:46 PM
Jer's Avatar
Jer
1994 E320
First things to check are spark plugs and injectors. The injectors themselves might be worn out, or the seals are leaking (allowing air ingression).
Old Feb 25, 2004 | 07:11 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Not to forget the spark plug cables. If the "missings" happen during damp and humide wheather conditions it may call for the cable(s). It is normally hard to determine which cable does it, especially it happens randomly only. If you still run the original cables take them out and clean them thoroughly and treat them with WD40. If it gets better then you know. Missing can also originating from a dirty, worn or damaged distributor cap and finger.
You have already rated this thread Rating: Thread Rating: 16 votes, 5.00 average.
