Did a few things today, look inside if you like to help. lol
Subscribe
Aug 10, 2016 | 09:21 PM
Did a few things today. 1. I am wheel shopping so I pulled the 8 holes that are on there to check the size they are 16x7.5 et38 with 205/55. The ones I want are 17x7.5 et 35 with 215/45, I think it should work. Can I use the stock lug nuts or should I get some other kind? 2. Since I had the tire off I was able to get under the rear and see how old the fuel filter was, well what I found was not good. I need to find a source for the fuel line from the tank to the others. I also probably should replace the filter, but what about the other parts down here? 3. I checked the spark plugs and they looked terrible. I need some new ones will the bosch f8dc4 be ok? And 4. I noticed that the vacuum line from the breather to the idle thing is not long enough to reach the breather hose, how much would that effect idle and how can I fix it?
Did a few things today, look inside if you like to help. lol-img_20160810_190312.jpg
Did a few things today, look inside if you like to help. lol-img_20160810_192422.jpgDid a few things today, look inside if you like to help. lol-img_20160810_192108.jpgDid a few things today, look inside if you like to help. lol-img_20160810_195340.jpg
Reply 0
Aug 11, 2016 | 05:56 AM
None resistor plugs for your engine .Nothing fancy . Also new copper washers on the banjo bolts after you get the replacment fuel pipe .Change the fuel filter while in there . And put a tin of fuel additive in the tank .Other members will help you i am sure
Reply 0
Aug 11, 2016 | 03:00 PM
Well no responses yet, and I cant get the fuel hose its out of stock everywhere. Hopefully someone will chime in soon
Reply 0
Aug 12, 2016 | 04:09 AM
Hanly if the fuel hose is not in stock. then go to an a shop the makes special hose up for hydraulic machines like presses and large lorries .Some one will make you one if you take the pipe for them to remove the special conector .Then they will crimp it in to new hose for you. Other than get one from a pick and pull yard, i thing thats what you guys call it.
Reply 0
Aug 12, 2016 | 05:12 PM
Thanks I might have to do that or just use a hose barb and a new piece of hose
Reply 0
Aug 13, 2016 | 04:24 AM
Hanly . Can ypu post a picuure of the item no4 you talk about in first post.?Vacuum pipe.If its got a vacuum leak it wont help .
Reply 0
Aug 15, 2016 | 11:04 AM
I found this post. apparently its not going to affect anything. https://www.google.com/url?sa=i&rct=...71359775381977
Reply 0
Subscribe
Currently Active Users (1)
