Suspension / wheel qustion
*if you have wheels with too much offset, they will stick out. theres nothing "phat" about that. it looks (east los angeles) ghetto.
*changing the shocks will not change that "wheel sticking out" phenomenon. you need new wheels.
*changing the shocks will not correct that "rubbing as i go over bumps if i have friends in the backseat" as long as you have those same wheels.
*if you only have one bump on your bump stops you are already on the lowest factory height short of a sportline suspension. cheap lower springs are probably available, but that is false economy. as are cheap anything.
get good brand names from reputable sources or learn the hard way. you still might learn a lesson from the wheels you have. that goes for springs, shocks, tires etc.
