HELP! 1989, 200e (w124) Manual
Old Mar 24, 2017 | 09:54 AM
Totte306's Avatar
Mercedes Benz 200 e (w124)
Welcome to an idiot.
I was out driving and got told to do a burnout...
As stupid iam i did, after like 15-30min my car was acting more and more wierd. i went to a parking lot and checked everything, nothing seemed wrong. Then when I started to drive of I did a sharp turn to the right and it would not move foward. I went to the lot in the first place becaus it pulled to the right...
I can change gear without clutch, R and 1 no sound. 2,3,4 it will start making wierd noises and speed meter goes up to 30km/h(18mph) but wont move. I suck at cars so please help.
Then the last question: can i take other mercedes part on to it and then what cars + can I put a 5speed gear on mine car when it has now a 4speed.
Old Mar 24, 2017 | 12:34 PM
optimusprime m1's Avatar
W124 260E
If its a manual gearbox i think your clutch or gearbox as gone
Old Mar 24, 2017 | 10:34 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
You may have blown the spider gears/carrier in the differential. The driveshaft is turning (hence the reading on the speedo which is driven by the output shaft of the transmission), but the power is not being transferred to the wheels. The spider cluster probably stayed together until you turned right which caused the spider gears to rotate and fall out of the carrier.
Old Mar 25, 2017 | 05:24 AM
W124 260E
Floby The drive shaft is not moving, and if it was, the car would move The drive shaft is in 2 parts ,one on the left and one on the right of the back axle, or pinion The parts that turn both the rear wheels , is it not? Propshaft is bolted to the gearbox flange May be we are thinking of the same thing only the name fro propshaft in the usa is not the same as uk ..
Old Mar 25, 2017 | 09:51 AM
Floobydust's Avatar
Sorry for the confusion in terminology - in the U.S. we would say that the "driveshaft" runs from the output of the transmission to the input of the differential. In Europe/UK it would be called the propeller shaft or prop shaft. The 2 "axle shafts" or "half shafts" run from the differential to each rear wheel.
Old Mar 25, 2017 | 12:23 PM
QVHK's Avatar
'90 300CE M103 Manual '93 Alfa 164 QV24 '05 Jaguar X350
Why race a 28 years old car? Unless the car was maintained in tip-top condition, the 15-30 minute burnout has done more damage than the normal wear and tear in its lifetime, and the damage was not limited to the clutch, gearbox and differential. I imagine that it won't be an economical repair.
Old Apr 15, 2017 | 01:28 PM
W124 260E
What a shame . Still its up to you now .The job is in your hands .
