Oil Pressure Readings at Idle
I saw an earlier thread on this topic, but still had some questions. When I apply any throttle my oil pressure climbs easily, but after the engine has warmed up a bit, the gauge always reads 0 Bar at idle. I've heard conflicting stories, some alleging the gauge is really more of a dummy switch and that it isn't a problem and some that say it's an issue. The car's been this way for awhile and I've seen no problems that would indicate a lack of oil pressure, and I check fairly often to make sure the engine is topped up, as I know these engines can sometimes be prone to leaking.
So my question is, does this happen to anyone else, and is it an issue that my gauge says I have no oil pressure at idle, even though I never lose pressure when using the throttle.
The car is a W124 Estate with the 3.2 M104 engine and about 126 thousand miles on the clock.
Thanks in advance to any that may have information on this!
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
You are being confused by all the misinformation over at Bens Wurld.
Oil pressure testing is done with a tool connected to the filter housing and the M104 pressures should be as follows:
600-700=1.3
600-700=1.3
Axel Trainwagon (05-09-2017)
You are confused with all the HS and misinformation at Bens Wurld. Oil pressure is tested with a tool connected to the oil filter and the pressures should be as follows:
600\700=1.3bar
1000=2.2
2000=4.8
3000=5.1
4000=5.3
you drive a 22 year old car, perhaps your gauge\system is dirty or faulty!!
600\700=1.3bar
1000=2.2
2000=4.8
3000=5.1
4000=5.3
