300TE differential rebuilding - HELP!!!
roller bearings, seals, gears, thrust rings, etc.
i asked for all the parts at ECStuning.com, as here in guatemala is very difficult to find parts, and if you find them are 3 times more expensive. well the spherical washer #26 are smaller, the 134 is taller, the bearings are bigger (taller and wider). dont know what to do ive tried everything here in guatemala to know the adequate parts for this car and nothing. hope you can help me to see what is wrong.
the vin is - WDB1240901F031308
i asked for this parts -
146 00259970047 SEAL RING - DRIVE PINIONDRIVE PINIONON
134 1083530042 SPACER BUSHING. SPACER SLEEVE - WITH ASD
131 0009808402 TAPERED ROLLER BEARING - WITH ASD
140 0019816905 TAPERED ROLLER BEARING - cross reference con timken M86649
20 1243530515 SIDE GEAR - WITH ASD
23 1073530014 DIFFERENTIAL PINION - WITH ASD
26 2013530124 SPHERICAL WASHER - WITHOUT ASD
53 0019802102 TAPERED ROLLER BEARING SIDE - WITH ASD
62 0149975747 SEAL RING - INTERIOR FLANGE
113 0049817125 BALL BEARING - WITH ASD
179 1244100615 flex joint shaft - front
176 2024101315 flex joint shaft - rear
Plenty available in eBay Germany.
but dont know what to ask as i wasnt able to find other part numbers.
the dealer in guatemala its a pain. this 300TE is from spain as there where not brought to guatemala, i searched for other diffs but there are not so many w124 around.
ive found 2 diffs, one was worst than mine and the other wasnt asd i guess because it was completly different this ones came from w124 sedans. i think this is the only 300te here in guatemala.
